DJI Phantom 4 Advanced Remote Controller Battery Replacement
  1. DJI Phantom 4 Advanced Remote Controller Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 4 Advanced Remote Controller Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 4 Advanced Remote Controller Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 4 Advanced Remote Controller Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 4 Advanced Remote Controller Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is attached to the back plastic, and is towards the bottom of the remote.
    • Unplug the cord that is connected to the bottom of the main board.
  7. DJI Phantom 4 Advanced Remote Controller Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the cord is unplugged, remove the battery by lifting upon the plastic cover, which the battery is attached to.
  8. DJI Phantom 4 Advanced Remote Controller Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the cover is off you can access the battery.
crwdns2935229:010crwdne2935229:0
cade knott
crwdns2935283:010/02/18crwdne2935283:0
511 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team S1-G4, Johnson Fall 2018 crwdns2935289:0Linn Benton Community College, Team S1-G4, Johnson Fall 2018crwdne2935289:0
LBCC-JOHNSON-F18S1G4
Wo kann ich den Akku bestellen? Danke für die Hilfe!
Xl S - crwdns2934203:0crwdne2934203:0
does someone know where to buy the akku?
Ich habe ein Erzatz Akku eingesetzt mit den gleichen Strom Werten, beim aufladen stelle ich fest das der Akku nicht ladet..
Es blinkt bloß ( schnell) auf einer LED.
Wo kann die Ursache liegen.
Matthias Meier - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 109
crwdns2942667:0crwdne2942667:0 14,626
