crwdns2959928:0crwdne2959928:0 ↓This guide will show the steps needed to remove the flight controller. In order to remove the flight controller, the cover will have to be removed first. Removing the flight controller will require disconnecting the wire connections on it.
With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
Turn the Phantom 3 Advanced upside down.
Remove the four 7mm long 2mm screws with a T-6 screwdriver.
Remove the eight 5mm long 2.5mm screws using the T-8 screwdriver.
Remove the four 10mm long deep 3mm screws using the T-8 screwdriver.
Carefully flip the phantom back over with the motors facing up.
Peel back the silver stickers from the seam in the cover.
Using a plastic spudger, slowly separate the two halves of the plastic shell.
Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
Press the tab on the side of the connector and pull up on the cable.
Continue to remove the shell the rest of the way.
Locate the five ribbon cables that need to be disconnected from the control board.
Locate the red and black battery wires.
Follow the three wires from each motor and the three wires from each LED to where they connect on the control board.
Use a plastic opening tool to remove the glue that covers the motor and LED wires. Use a metal opening tool if necessary.
Desolder the six motor and LED wires where they connect on the flight controller for each arm. Refer to the Desoldering Guide on how to desolder.
Desolder the battery wires.
Remove the cable next to where the battery wires were connected. Pinch and hold the top of the connector, then pull it out.
Remove the black ribbon cable and the 3-wire cable next to it. Press the small tab on the ribbon cable connector and pull it out.
Locate the ribbon cable that is next to the word "Front" on the flight controller.
Remove the small cable next to the ribbon cable by pinching on the side tab and pulling up on the connector. It has black, red and yellow wires.
Remove the black band from the ribbon cable.
Remove the ribbon cable by pinching on the side tab and pulling up on the connector.
Remove the four 6.5mm long 2mm screws with a philips head 00 screwdriver.
Remove the flight controller now by slowly pulling if off of the frame.
crwdns2935229:011crwdne2935229:0
Very clear and helpful. Thank You.
Herb - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Excellent with great visuals. Can really see what to do
Leo Miller - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
