DJI Phantom 3 Advanced Cover Replacement
  1. DJI Phantom 3 Advanced Cover Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 3 Advanced Cover Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 3 Advanced Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Cover Replacement, Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the Phantom 3 Advanced upside down.
  4. DJI Phantom 3 Advanced Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 7mm long 2mm screws with a T-6 screwdriver.
    • There is one screw per arm, located at the tip of the arm.
  5. DJI Phantom 3 Advanced Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 3 Advanced Cover Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 5mm long 2.5mm screws using the T-8 screwdriver.
    • There are two 5mm screws on each arm.
  6. DJI Phantom 3 Advanced Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 3 Advanced Cover Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 10mm long deep 3mm screws using the T-8 screwdriver.
    • There is one screw on each arm located near the landing gear.
  7. DJI Phantom 3 Advanced Cover Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DJI Phantom 3 Advanced Cover Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DJI Phantom 3 Advanced Cover Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully flip the phantom back over with the motors facing up.
    • Peel back the silver stickers from the seam in the cover.
    • Using a plastic spudger, slowly separate the two halves of the plastic shell.
    • This step requires some force, and the plastic will click loudly as the shell separates.
    • Do not fully remove the cover. There is a wire that needs to be detached from the control board before the cover is completely free.
  8. DJI Phantom 3 Advanced Cover Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DJI Phantom 3 Advanced Cover Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DJI Phantom 3 Advanced Cover Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
    • Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
    • Press the tab on the side of the connector and pull up on the cable.
    • Continue to remove the shell the rest of the way.
    “Press the tab on the side of the connector and pull up on the cable.”
    The 2015 W323A model I am working on has no tab on the side of the connector. Connector released quite easily when I applied upward pressure away from the board, pulling on the all wires together. A little wiggle side to side helped. Be patient. It’s a small connector.
    O Smith - crwdns2934203:0crwdne2934203:0
crwdns2935229:011crwdne2935229:0
Robert Comstock
crwdns2935283:010/06/16crwdne2935283:0
433 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-2, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 10-2, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S10G2
Great Job Robert! Even the “Phantom Pilots Forum” had no recent recommendations for a disassembly manual, as DJI likes to “Fixit” themselves!
Michael Steinbrecher - crwdns2934203:0crwdne2934203:0
Excellent detailed instructions. Having pictures on procedure makes it idiot proof.
Bolo - crwdns2934203:0crwdne2934203:0
Does this also include the phantom 3 professional too? My understanding is that the only differences between them is the battery charger and the pro is 4k recording vs 1080p.
John D - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 5,141
