DJI Phantom 2 Vision Outer Shell Replacement
    1. DJI Phantom 2 Vision Outer Shell Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The battery is located on the backside of the drone. You will see a large rectangular indent protruding outward.
      • The "battery" shown in the image is for illustrative purposes only. Since the original battery was missing, we constructed this one to demonstrate the repair process. The actual battery will not stick out this much.
    2. DJI Phantom 2 Vision Outer Shell Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 2 Vision Outer Shell Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the battery from the compartment by pinching the top and bottom pressure points near the center and pulling the battery towards you.
    3. DJI Phantom 2 Vision Outer Shell Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Clean the battery compartment using cotton swabs and isopropyl alcohol or pressurized air to remove any debris or dust inside.
      • Repeat these steps after every battery replacement to prevent damage to the drone’s internal components.
    1. DJI Phantom 2 Vision Outer Shell Replacement, Outer Shell: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 2 Vision Outer Shell Replacement, Outer Shell: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the propellers before taking off the top shell. Refer to the DJI Phantom 2 Vision+ Propellers Removal for detailed instructions, as the process is identical.
      • Flip the device so the motors are facing down.
      • Remove four 6 mm screws next to the landing gear on each arm using a 2 mm Hex key.
    2. DJI Phantom 2 Vision Outer Shell Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove eight 9 mm screws using a 2 mm Hex key.
      • Remove four 9 mm screws using a Phillips #00 screwdriver.
    3. DJI Phantom 2 Vision Outer Shell Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 2 Vision Outer Shell Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slowly lift the shell off the device.
      • Disconnect the GPS wire from the motherboard.
Dylan Ponder
crwdns2935283:009/15/24crwdne2935283:0
386 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 7-1, Watkins Fall 2024 crwdns2935289:0Austin Community College, Team 7-1, Watkins Fall 2024crwdne2935289:0
AUSTINCC-WATKINS-F24S7G1
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 327
