DJI Phantom 2 Vision Gimbal Housing Replacement
  1. DJI Phantom 2 Vision Gimbal Housing Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is located on the backside of the drone. You will see a large rectangular indent protruding outward.
    • The "battery" shown in the image is for illustrative purposes only. Since the original battery was missing, we constructed this one to demonstrate the repair process. The actual battery will not stick out this much.
  2. DJI Phantom 2 Vision Gimbal Housing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 2 Vision Gimbal Housing Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery from the compartment by pinching the top and bottom pressure points near the center and pulling the battery towards you.
  3. DJI Phantom 2 Vision Gimbal Housing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clean the battery compartment using cotton swabs and isopropyl alcohol or pressurized air to remove any debris or dust inside.
    • Repeat these steps after every battery replacement to prevent damage to the drone’s internal components.
  4. DJI Phantom 2 Vision Gimbal Housing Replacement, Gimbal Housing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 2 Vision Gimbal Housing Replacement, Gimbal Housing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the propellers before you begin. Refer to the DJI Phantom 2 Vision+ Propellers Removal for detailed instructions, as the process is identical.
    • Flip the drone over so the bottom is facing up.
    • Use a Phillips #00 screwdriver to remove the four 6 mm screws.
    • To access the screws, slowly pull back on the mount in the opposite direction.
  5. DJI Phantom 2 Vision Gimbal Housing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 2 Vision Gimbal Housing Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the wire connecting the camera to the drone.
  6. DJI Phantom 2 Vision Gimbal Housing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 2 Vision Gimbal Housing Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly lift the gimbal housing from the device.
    • Gently disconnect the camera cable from the cable connected to the motherboard.
    • Push on alternating sides of the connector and pull straight away from the socket.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
    • Do not pull on the wire cables as this may cause damage.
    • The gimbal housing should now be disconnected from the drone.
Dylan Ponder
crwdns2935283:009/15/24crwdne2935283:0
386 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 7-1, Watkins Fall 2024 crwdns2935289:0Austin Community College, Team 7-1, Watkins Fall 2024crwdne2935289:0
AUSTINCC-WATKINS-F24S7G1
crwdns2942667:0crwdne2942667:0 113
