DJI Mini 3 Pro Gimbal Replacement
crwdns2937549:0crwdne2937549:0
To reassemble your device, follow these instructions.
crwdns2935229:08crwdne2935229:0
Arty
crwdns2935283:010/27/19crwdne2935283:0
28 582 crwdns2915208:0crwdne2915208:0
crwdns2935297:095crwdne2935297:0
crwdns2947412:012crwdne2947412:0
Does anyone have a source for replacing the little rubber gimbal mounts?
Andre Purdy - crwdns2934203:0crwdne2934203:0
HI there! Does anyone know where I can buy the whole gimbal in USA? I remember seeing it somewhere but cannot find it
gbonilla - crwdns2934203:0crwdne2934203:0
Go to YouTube and check the link to the gimbal assembly in the description below the video
Arty -
mini 3 pro com port not show on device manegar any help.
Limon Khan - crwdns2934203:0crwdne2934203:0
Bonjour, le port COM ne s'affiche pas sur mon pc, comment faire ?
Sébastien Perroux -
Start trembling during flight after a horizontal stop. At the start, I can hear the gimbal noise from trembling (before taking off). I gently touch it, and it stops. I take off and fly a long distance.
If I stop it or it stops it by signal loss, the trembling starts again. if I never stop it and take gentle curves back, it may work. At abrupt stops, it starts trembling. I bring the drone back to me at 1-meter height. I gently touch the gimbal (without landing), and it stops. Then I fly again (if the battery is low, I land, change the battery, and start again, same steps, every time). I will probably buy a new one, so I can send this to repairs - did not check the guarantee yet.
- no problems during climbing up.
- only on horizontal movements and hard stops (release the lever on the controller).
I will try never to release the lever abruptly and never lose signal (a signal lost could be a hard brake, also)
??? Calibration can stop this strange error ????
Dorin - crwdns2934203:0crwdne2934203:0
Check the metal piece of the gimbal to make sure it is not broken anywhere. That can cause the camera to vibrate.
Frankie Snaps -
bonjour,
ou peut on trouver la piece neuve ?
Cédric Rovelli - crwdns2934203:0crwdne2934203:0
Hey what parts do I need to get and where to get them from in au. I crashed and it’s broken the right side of the gimbal completely off. The camera still looks fine and working but there is a cable snapped off. any help would be much appreciated
Brody D - crwdns2934203:0crwdne2934203:0
I don't know how to get the parts in AU, but I just had the same problem and fixed it. If the motors still rotate, then it shouldn't be too hard (or expensive) to fix. I just replaced the cable, the plastic covering and the rubber dampeners, and it worked. This was the video that was really helpful.
https://youtu.be/fiebNX5f1r8?feature=sha...
MJT -
There was no link to order the Gimbal replacement part???
citsalllc - crwdns2934203:0crwdne2934203:0
Hey - I recently knocked my Mini 3 Pro into a wall, there was a slight crack to the body but nothing bad HOWEVER the cable feeding into the camera/gimbal is exposed as the plastic part originally there (only a little circular ish piece on the back of the camera) came off. Any idea what that is called and where I can get it? Thanks
AdamD - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 116
crwdns2936753:030crwdne2936753:0 471
crwdns2942667:0crwdne2942667:0 26,986
