The DJI Mini 3 was released in December 2022 as a slightly more affordable alternative to the Mini 3 Pro.
Ambarella H22-A0-RH H22 quad-core video SoC
Kingston D1216ECMDXGME-U 256 MB DDR3L SDRAM memory
HDSC HC32F460JEUA 32-bit ARM Cortex-M4 microcontroller
Qualcomm SMB2352–207 dual-cell Li-ion battery charger
Monolithic Power Systems MP6507GQ stepper motor driver w/ MOSFETs
Silergy SY6280AAC power distribution switch
OmniVision WAS7222Q 480 Mbps DPDT analog switch
Texas Instruments TLV75901P 1 A / adj. LDO regulator
OmniVision WL2836D12 300 mA / 1.2 V LDO regulator
OmniVision WL2836D18 300 mA / 1.8 V LDO regulator
OmniVision WL2848D18 300 mA / 1.8 V LDO regulator
OmniVision WL2836D25 300 mA / 2.5 V LDO regulator
Nexperia 74LVC2T45 dual supply translating transceiver
Nexperia 74LVC1G08 single 2-input AND gate
Yangjie Electronic Technology YJQ1216A P-Channel MOSFET
Possibly Leadcore S1 RF transceiver
Kangxi Communication Technologies KCT8247HE-1 2.4 GHz WLAN front-end module
Kangxi Communication Technologies KCT8576N 5 GHz WLAN front-end module
Likely Maxscend MXDx213 low noise amplifier
Likely Maxscend DPDT RF switch
Likely Maxscend MXD8622E SPDT RF switch
NXP Semiconductor MIMXRT1064DVL6B i.MX single core application processor
Kioxia TC58NVG1S3HBAI6 256 MB NAND flash memory
Monolithic Power Systems MP6543HGL 3-phase power stage
Silicon Content Technology SCT2260A 6 A synchronous step-down DC-DC converter
Silicon Content Technology SCT2230 3 A synchronous step-down DC-DC converter
Monolithic Power Systems DC-DC Converter
Possibly Linearin LTP3330 300 mA / 3.0 V LDO Regulator
OmniVision WL2836D33 300 mA / 3.3 V LDO regulator
Synaptics SYN43456PXKUBG single-chip 5G WiFi 802.11ac w/ Bluetooth 5 & FM receiver
Texas Instruments OPT3101 distance sensor analog front-end
SG Micro SGM2036-1.2 300 mA / 1.2 V LDO regulator
SG Micro SGM2036-1.8 300 mA / 1.8 V LDO regulator
SG Micro SGM2036-2.8 300 mA / 2.8 V LDO regulator
TDK-InvenSense ICM-40609-D 6-axis MEMS accelerometer & gyroscope
Goertek SPL06-001 pressure and temperature sensor
u-blox UBX-M10050-KB GNSS receiver
Maxscend MXDLN16TP GNSS low noise amplifier
Murata SAFFB1G56KB0F5F SAW filter BeiDou/Galileo/GLONASS/GPS
Texas Instruments DRV8328B 3-phase BLDC gate driver
Spintrol SPC1168APE48 32-bit ARM Cortex-M4 microcontroller
Vergiga VS3622DB 30 V dual N-channel MOSFET
MEMSIC MMC5983MA 3-axis magnetometer
Texas Instruments BQ9003 battery fuel gauge (likely)
Advanced Power Electronics Corp. AP3N1R8MT 30 V N-channel MOSFET
Perfect sharing
It's great. Thank you. Did you also disassemble the dji mini4 or mini4 pro like that?
Hi. Do you have high resolution on main board? I had my drone played submarine, so I had to clean the board. Few resistors located at the left of LEDs brushed out :(
