DJI Mavic Pro Gimbal/Camera Replacement
  1. DJI Mavic Pro Gimbal/Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DJI Mavic Pro Gimbal/Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DJI Mavic Pro Gimbal/Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro Gimbal/Camera Replacement, Upper Shell: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
  6. DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
  8. DJI Mavic Pro Gimbal/Camera Replacement, Gimbal/Camera: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the one 5mm JIS #0 screw from the small micro controller board at the front of the DJI Mavic Pro by turning counterclockwise.
  9. DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the cord and micro controller board away from the front of the DJI Mavic Pro using tweezers.
  10. DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Expose the two small ZIF connectors near the front of the board by removing the plastic coverings.
    • Then, remove the two ZIF connectors under the coverings using a nylon spudger.
  11. DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 6mm JIS #00 screws from the plastic board cover at the front of the DJI Mavic Pro.
  12. DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the DJI Mavic Pro over.
    • Gently press the latch for the Gimbal cover.
    • Pull the cover off.
  13. DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the DJI Mavic Pro back over, with its top side facing up.
    • Remove the two ZIF connectors located behind the plastic covers by using a nylon spudger.
  14. DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the power cable connector located to the left, behind the gimbal board, by pulling up on the white base.
  15. DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Scrape away the plastic adhesive covering the two 5mm JIS #000 screws connected to the gimbal board.
    • Remove the two 5mm JIS #000 screws from the gimbal board by turning the screwdriver counterclockwise.
  16. DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 7mm JIS #00 screws at the very front of the DJI Mavic Pro by turning the screwdriver counterclockwise.
    • Careful when removing these screws the camera or whatever remains of your camera assembly may drop
  17. DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Mavic Pro Gimbal/Camera Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the DJI Mavic Pro over, with the camera facing you.
    • Gently pull the gimbal/camera assembly up and out.
crwdns2935229:056crwdne2935229:0
Nicole Lai
crwdns2935283:010/08/18crwdne2935283:0
529 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G3, White Fall 2018 crwdns2935289:0Cal Poly, Team S17-G3, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S17G3
crwdns2935297:020crwdne2935297:0
crwdns2947412:09crwdne2947412:0
Bonjour,
Merci pour cette tuto qui m’a permis d’effectuer la manipulation sans problème. Mais il se fait qu’après le changement de tout le cadran de la caméra avec le câble plat (Gimbal) achété sur amazon, tout s’affiche normalement, sauf que l’écran reste noir, aucun retour vidéo et aucune photo enregistrée. J’ai vérifié que toutes les connexions sont bien effectuées.
Pourriez-vous avoir une idée de ce qui peut être la cause?
Merci d’avance
Alain
Alain Lushimba - crwdns2934203:0crwdne2934203:0
Alain J'ai eu ce même problème (avec une surcharge de cardan et une erreur de gyroscope) j'ai remplacé le câble tressé de la caméra (celui avec un tas de fils collés ensemble) et cela a réparé ma caméra et mon cardan. Maintenant, mon drone fonctionne parfaitement.
(J'ai utilisé google translate donc je n'ai aucune idée si cela est écrit correctement)
J'espère que cela aide !!
-Eli
ELI KEARL -
Thanks! Overall, these are great instructions!
Removing the front end of the top cover was challenging, as it required some strength and confidence. It helped to reach in and disconnect the large white connector (step 7) before completely removing the top cover (step 6), as suggested here: DJI Mavic Pro Top Case Removal.
Step 15 turns out to be unnecessary — the two screws covered in plastic adhesive fasten the gimbal’s circuit board to the gimbal’s mounting plate, all of which come out together.
Eric Stollnitz - crwdns2934203:0crwdne2934203:0
Those aren’t ZIF connectors. They are FPC connectors.
David Boyd - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 97
crwdns2936753:030crwdne2936753:0 429
crwdns2942667:0crwdne2942667:0 49,197
