DJI Mavic Pro Front Arm Assembly Replacement
  1. DJI Mavic Pro Front Arm Assembly Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 6 hex screws from top cover. These are 1.5 mm and the same length.
  2. DJI Mavic Pro Front Arm Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two hex screws on either side of the gimbal. These are 1.5 mm and the same length as the 6 top cover screws.
    • Remove two smaller hex screws from the covers under the front arms. These are 1.5 mm and SHORTER than the prior screws.
  3. DJI Mavic Pro Front Arm Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to remove the covers under the front arms
    • These covers are fitted tightly enough that it's difficult to get a pry tool underneath. I found that when I pressed my thumb against the outside corner (red arrow) I got just enough of a gap on the opposite side (orange arrow) to squeeze a pry tool into it.
  4. DJI Mavic Pro Front Arm Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Mavic Pro Front Arm Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 1.5mm hex screws under the cover
  5. DJI Mavic Pro Front Arm Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Mavic Pro Front Arm Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the back end of the cover
    • The cover is connected to the body by a cable. Don't open the cover all the way until this cable is unplugged!
    • Unplug the 6-pin GPS connector, then pry along the edges to release the plastic clips holding the top down
    • Remove the cover
    • The clips at the nose of the drone require some extra pressure to release
  6. DJI Mavic Pro Front Arm Assembly Replacement, Desolder the arm wires: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the larger gray motor wire running to the arm to be replaced
    • Desolder the larger white motor wire
    • Desolder the larger black motor wire
    • Desolder the smaller black LED wire
    • Desolder the smaller white LED wire
    • The marked wires are for the right arm. The wires to desolder when replacing the left arm are the mirror image of the ones shown here.
    • Don't forget that plastic has a tendency to melt when exposed to heat! I may or may not have disregarded this fact and put a mark on my drone...
  7. DJI Mavic Pro Front Arm Assembly Replacement, Remove the bottom heat plate: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 2 hex screws with longer posts
  8. DJI Mavic Pro Front Arm Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove bottom heat plate
    • This plate may stick a bit due to the thermal compound underneath it. It's a good idea to replace the thermal paste during reassembly
  9. DJI Mavic Pro Front Arm Assembly Replacement, Antenna cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If replacing the right front leg, unplug the white front antenna cable
    • If replacing the left front leg, unplug the black front antenna cable
  10. DJI Mavic Pro Front Arm Assembly Replacement, Remove front leg: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the top of the drone, gently release the rear leg cable bundle from its cable management clip
    • Lift the white or black wire from the previous step up through the drone
  11. DJI Mavic Pro Front Arm Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Phillips head screw below the arm to be replaced
  12. DJI Mavic Pro Front Arm Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Mavic Pro Front Arm Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a metal pry tool or flat head screwdriver to lift out the spring-loaded hinge
    • The spring in this hinge makes it difficult to reseat during reassembly. The easiest way I found to replace it was to fold the arm back into the closed position, and then grab across the top of the hinge with the very tip of a pair of needle nose pliers, using the pliers to rotate the hinge into position and press it down into place.
  13. DJI Mavic Pro Front Arm Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the arm
Jamie Bell
crwdns2935283:008/01/19crwdne2935283:0
433 crwdns2915208:0crwdne2915208:0
Bravo, thanks for the guide! I found myself in the middle of my repair cursing that antenna wire as I didn’t want to pull up the main board. Then I remembered my trusty secret weapon “ifixit.com”. Oh did you save the day for sure, I was hoping for another access point to unclip the antenna, just had no idea where that would be. I’ve been a fixer for 20 + years, but DJI drones are not something you generally just want to go poking and prodding around blind. So a big thanks for helping me get in and out with ninja precision fellow fixer!
Caleb Fitzgerald - crwdns2934203:0crwdne2934203:0
Glad I could help! They’re definitely complicated little buggers.
Jamie Bell -
Did you use some glue along the three wires for the motor arm? This was destroyed when I replaced one damaged arm. Do you know what type of glue would be good to use?
jookieapc - crwdns2934203:0crwdne2934203:0
I didn’t use any glue, and I haven’t had any issues with it leaving it out. It looks like the original glue is some sort of silicone glue. I would think you could probably use an electronics-safe silicone adhesive, like something you could get from a hobby shop, but I haven’t tried it myself so I couldn’t say for sure.
Jamie Bell -
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 121
crwdns2942667:0crwdne2942667:0 4,808
