DJI Mavic Mini Propeller Replacement
  1. DJI Mavic Mini Propeller Replacement, DJI Mavic Mini Propeller Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DJI Mavic Mini Propeller Replacement, DJI Mavic Mini Propeller Replacement: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DJI Mavic Mini Propeller Replacement, DJI Mavic Mini Propeller Replacement: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Identify the drone propellors.
    • The drone propellers have a different design on the tip, with one consisting of two silver strips, and the other with only one. Refer to the third image.
    • There is a bump on the propellor with the two silver stripes, located near the screw. This helps indicate the side of the the propeller goes on, as there is an indent on that side near the propeller motor on the drone. Refer to the first image.
  2. DJI Mavic Mini Propeller Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DJI Mavic Mini Propeller Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DJI Mavic Mini Propeller Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a JIS #000 screwdriver to gently unscrew and remove the propellers.
    • Unscrew the propellers counter-clockwise, while holding onto the propeller motor of the drone to prevent movement.
  3. DJI Mavic Mini Propeller Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DJI Mavic Mini Propeller Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DJI Mavic Mini Propeller Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert your new propellers into the hole closer to centre of the motor.
    • This also applies for the second propeller on the same motor. Refer to the second image.
    • You may replace the screw if needed as well, if the previous screw is damaged.
    • Make sure you know which propeller goes where. This is important as a wrong placement can cause unstable flight.
  4. DJI Mavic Mini Propeller Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Double check if your propellers are on properly.
    • Check for any loose screws or propellers.
    • Gently pull on the new propellers you had just replaced.
  5. DJI Mavic Mini Propeller Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently move your Mavic Mini drone around, rotate it a couple of times to indicate any loose parts.
    • If you notice any loose screws or propellers, you would need to tighten it, if there is an issue with the screw, the screw may need to be replaced.
  6. DJI Mavic Mini Propeller Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do one last check to make sure the propellers are on their proper sides.
    • Do one last check for any loose screws or propellers.
    • If you notice any propellors on the wrong side, you will have to redo the each step.
After this guide, you’ll be able to replace your DJI Mavic Mini propellers easily.
Maximillian Dow
crwdns2935283:001/20/22crwdne2935283:0
187 crwdns2915208:0crwdne2915208:0
York University, Team 2-7, O'Regan Winter 2022 crwdns2935289:0York University, Team 2-7, O'Regan Winter 2022crwdne2935289:0
YORK-O'REGAN-W22S2G7
crwdns2936753:030crwdne2936753:0 97
crwdns2942667:0crwdne2942667:0 6,470
