DBPOWER T20 Lens Replacement
  1. DBPOWER T20 Lens Replacement, DBPOWER T20 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device and lay flat.
  2. DBPOWER T20 Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DBPOWER T20 Lens Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DBPOWER T20 Lens Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DBPOWER T20 Lens Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DBPOWER T20 Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DBPOWER T20 Lens Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DBPOWER T20 Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DBPOWER T20 Lens Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DBPOWER T20 Lens Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Lens Replacement, Lens: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The lamp does not need to be removed for this step to be preformed.
  12. DBPOWER T20 Lens Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the keystone adjuster from the lens housing.
    • Lens is on a hinge so it should lift off easily, if it doesn't, adjust by swaying it forward or backward.
  13. DBPOWER T20 Lens Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber foot and warranty sticker found underneath the device.
  14. DBPOWER T20 Lens Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DBPOWER T20 Lens Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws on the bottom of the device with a J0 screwdriver.
  15. DBPOWER T20 Lens Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the focus-adjustment ring from the lens housing.
Andrea Espinosa
crwdns2935283:002/15/18crwdne2935283:0
521 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S16-G2, Boczar Spring 2018 crwdns2935289:0USF Tampa, Team S16-G2, Boczar Spring 2018crwdne2935289:0
USFT-BOCZAR-S18S16G2
How does the lens parts go together?
Lay - crwdns2934203:0crwdne2934203:0
Trying to put my lens back how to install
David Williams - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,683
