DBPOWER T20 Disassembly
Andrea Espinosa
crwdns2944107:0crwdnd2944107:0Andrea Espinosacrwdnd2944107:0crwdnd2944107:0crwdnd2944107:05crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kho 6, 2018crwdne2944111:0
crwdns2931287:015crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
If you need to repair anything on the DBPOWER T20 Projector you need to disassemble it first. This guide will show you all the steps necessary to disassemble the device to a point where items can be replaced. It is quite a sturdy device so don't be afraid to use some force removing the top of the device and the wired. However, use caution around the mirrors inside the device.
  • Spudger
    Spudger
  1. DBPOWER T20 Disassembly, DBPOWER T20 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device and lay flat.
  2. DBPOWER T20 Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DBPOWER T20 Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DBPOWER T20 Disassembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
    looks hard and tightly connected. put an arrow
    Ki Ko - crwdns2934203:0crwdne2934203:0
  5. DBPOWER T20 Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DBPOWER T20 Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
    one of the screws have been stripped, I’ve tried the rubber band and the glue trick, it didn’t work. What do I do to remove it? please respond
    arman waggoner - crwdns2934203:0crwdne2934203:0
  6. DBPOWER T20 Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DBPOWER T20 Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DBPOWER T20 Disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DBPOWER T20 Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
    very well explained, let's also tell the other one how it goes
  8. DBPOWER T20 Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Raise motherboard by lifting sideways and then up to avoid the ports.
    hard, very hard, I have a feeling that something will break
  9. DBPOWER T20 Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DBPOWER T20 Disassembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DBPOWER T20 Disassembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
Andrea Espinosa
crwdns2935283:002/15/18crwdne2935283:0
521 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S16-G2, Boczar Spring 2018 crwdns2935289:0USF Tampa, Team S16-G2, Boczar Spring 2018crwdne2935289:0
USFT-BOCZAR-S18S16G2
Anyone find a bulb for this thing? And/or know what else (or a quick fix) would fix a dark or burn mark on the image?
jcr4130 - crwdns2934203:0crwdne2934203:0
haing the same issue tried to call a electronics repair place to see if the could order a new polarizing lens for me and they said they could not unless they were the ones that did the repair
derek_russell82308 -
Really? Well, crap
KweenBeeTX -
How are the lenses supposed to sit in the hompow t20 mini projector
Joseph Duffey - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,051
