DBPOWER RD-810 Fan Replacement
  1. DBPOWER RD-810 Fan Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DBPOWER RD-810 Fan Replacement, Top Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Fan Replacement, Motherboard and LED Bulb: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DBPOWER RD-810 Fan Replacement, Motherboard and LED Bulb: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DBPOWER RD-810 Fan Replacement, Motherboard and LED Bulb: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DBPOWER RD-810 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DBPOWER RD-810 Fan Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DBPOWER RD-810 Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DBPOWER RD-810 Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
  6. DBPOWER RD-810 Fan Replacement, Fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the fan up and out of the projector.
John Russell
crwdns2935283:002/14/18crwdne2935283:0
941 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S5-G3, Eyestone Spring 2018 crwdns2935289:0USF Tampa, Team S5-G3, Eyestone Spring 2018crwdne2935289:0
USFT-EYESTONE-S18S5G3
Wich cooler does fit ? I just bought the Projector and want to change the Fan because it is too loud
pr0mqu33nkill3r - crwdns2934203:0crwdne2934203:0
Do you know the fan size / model? I bought one of these projectors but the fan is way to loud. I want to replace it for a quiet one
Luis - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 817
