This guide is going to show how to take apart a D-Link DCS 936L Wi-Fi security camera and remove the camera lens using a Phillips #00 screwdriver and an opening tool. Don't fear! This is fairly simple once you get started. As long as you are careful not to strip the screws, it should only take a few minutes.
Place the camera upwards between your thumb and first finger.
Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
After removing the screws, there are 4 tabs holding the back cover on. Each tab is located at the edge of a vent. Pry at each point to remove the back cover. Take care not to damage the Micro SD card holder.
Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
Then (gently!) remove the motherboard and the lens with your fingers.
There are two Phillips #00 6.0mm screws keeping the camera in place. Remove the screws first.
Gently unplug the camera from the motherboard, and remove the camera.
How do I get hold of a replacement lens? Can’t seem to find anyone selling them. Need one for a DCS-2670L
