D-Link DIR-890L Reset Button Replacement
  1. D-Link DIR-890L Reset Button Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the router so the narrow end of the router faces you and the ports face away from you.
    • The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
  2. D-Link DIR-890L Reset Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Reset Button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Reset Button Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Heavy-Duty Spudger
  3. D-Link DIR-890L Reset Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 D-Link DIR-890L Reset Button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue to pry off the last three antenna connections on the upper right portion of the motherboard.
  4. D-Link DIR-890L Reset Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Reset Button Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Reset Button Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the plastic bracket enclosing the three antenna wires and pull the wires out with your hands.
  5. D-Link DIR-890L Reset Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Reset Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Reset Button Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the yellow tape off of the motherboard to release the final antenna wire.
  6. D-Link DIR-890L Reset Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 D-Link DIR-890L Reset Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the the motherboard away from the case to remove it. Start on the side closest to you, and pull up and out.
  7. D-Link DIR-890L Reset Button Replacement, Reset Button: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Reset Button Replacement, Reset Button: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Reset Button Replacement, Reset Button: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the reset switch at the top of the motherboard.
    • Flip the motherboard over.
    • Locate the reset switch's 4 solder joints on the underside of the motherboard.
  8. D-Link DIR-890L Reset Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Desoldering Pump
    $3.99
    • Using a soldering iron and desoldering pump, desolder the reset switch from the board.
    • For more information, see this guide on desoldering.
Rachel Shaw
crwdns2935283:010/06/16crwdne2935283:0
553 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-7, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 10-7, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S10G7
crwdns2942667:0crwdne2942667:0 1,134
