Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
Remove the back casing to expose the circuit board.
Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
Detach the speaker wire by gently pulling on the side closest to the body of the camera.
Remove the two 7.25 mm screws using the Ph00 head.
Remove the speaker by gently pulling on the wire near the speaker.
