CyberpowerPC Fangbook HX6 Screen Replacement
  1. CyberpowerPC Fangbook HX6 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To replace the screen you will need a screwdriver (a size zero was used in this guide), and a tool that can be used to pry off the screen covering (a spudger was used in this guide).
  2. CyberpowerPC Fangbook HX6 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 CyberpowerPC Fangbook HX6 Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 CyberpowerPC Fangbook HX6 Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the spudger gently into the seam that connects the front plate to the rest of the device.
    • Move the tool carefully around the screen and apply a small amount of pressure. You are trying to undo several clasps holding the front plate on.
    • Do this on all sides of the face plate except for the bottom. The bottom will have a strip of adhesive you will need to carefully pull off to separate the face plate from the bottom of the screen.
  3. CyberpowerPC Fangbook HX6 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CyberpowerPC Fangbook HX6 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4mm silver screws on both sides of the top of the screen.
    • Once you have removed them, gently pull the screen off of the aligning dials (the small plastic pieces to the left of the screws).
  4. CyberpowerPC Fangbook HX6 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CyberpowerPC Fangbook HX6 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At this point the only thing keeping the screen attached to the laptop is this small wire and connector shown here.
    • Gently pull the screen out and turn it over so that you can see where the connector is attached.
    • Carefully remove it. Once this is done you have successfully removed the screen from your laptop.
Eric Box
crwdns2935283:009/12/18crwdne2935283:0
183 crwdns2915208:0crwdne2915208:0
University of Alabama, Team S1-G4, Bedsole Fall 2018 crwdns2935289:0University of Alabama, Team S1-G4, Bedsole Fall 2018crwdne2935289:0
UA-BEDSOLE-F18S1G4
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 979
