CyberPowerPC RGB 7 Color LED Backlight Replacement
crwdns2869540:0crwdne2869540:0: 1739
8
49
1,739
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:03crwdne2931287:0
The LED backlight may burn out, causing the backlight to cease working properly. This guide will demonstrate how to replace the LED backlight.
    1. CyberPowerPC RGB 7 Color LED Backlight Replacement, Plastic Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CyberPowerPC RGB 7 Color LED Backlight Replacement, Plastic Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Be sure to unplug the keyboard before starting the disassembly.
      • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
    2. CyberPowerPC RGB 7 Color LED Backlight Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CyberPowerPC RGB 7 Color LED Backlight Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the sixteen 5 mm length screws using the Phillips head #2.
      • One of the screws may be located underneath a manufacturer's sticker.
    3. CyberPowerPC RGB 7 Color LED Backlight Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift up and remove the plastic casing.
    1. CyberPowerPC RGB 7 Color LED Backlight Replacement, LED Backlight: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the metal backing located directly underneath the white plastic casing.
    2. CyberPowerPC RGB 7 Color LED Backlight Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Be careful not to pull too hard on the ribbon cable, as it may break.
      • Disconnect the ribbon cable that connects the LED board to the motherboard.
    3. CyberPowerPC RGB 7 Color LED Backlight Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully remove the LED board, which should now come free from the casing.
Braydon Lantz
crwdns2935283:002/12/18crwdne2935283:0
229 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S15-G2, Boczar Spring 2018 crwdns2935289:0USF Tampa, Team S15-G2, Boczar Spring 2018crwdne2935289:0
USFT-BOCZAR-S18S15G2
crwdns2936753:030crwdne2936753:0 49
crwdns2959996:0crwdne2959996:0 1,739
