Cuisinart Velocity Ultra Trio Blender Clutch Replacement
  1. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Find and remove four screws on bottom: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Find and remove four screws on bottom: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You will need to pull out the back rubber feet to get at the screws.
  2. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove base from Blender: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove base and release power cord.
  3. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove plastic support: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove plastic guard and make note of the way it fits.
  4. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove motor screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove motor screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove Back two motor screws
    • Remove front two motor screws
  5. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove the clutch from the motor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove the clutch from the motor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove the clutch from the motor: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the clutch you will need to use the flat head screw driver and twist the clutch clockwise as the thread to tighten it are reverse threaded.
    • The clutch could be worn out and not be gripping the screw and might need to be pulled off.
    • *This might be a difficult step as you are still connected to the top. If you want to try a bit of heat to melt the clutch plastic might be a solution.
  6. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove screw from end of motor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove screw from end of motor: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Remove screw from end of motor: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the clutch didn't come off in one piece and you need to remove the nut. You will need to turn it clockwise as it is reverse threaded.
    • Using vise grips helped hold onto the nut while you can use a screw driver to turn clockwise or hold the plastic fans blades. * Because to not break a blade off as it will cause the motor to be off balance.
  7. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Insert motor and tighten: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Insert motor and tighten: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Insert motor and tighten: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure to not lose the washer.
    • Move the rubber seal to the top so you won't get any leaks into the blender.
    • Replace the four washers.
    • Replace motor and tighten four screws.
  8. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Connect new clutch to motor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn on side.
    • Make sure washer and rubber seal are in the correct position.
    • Tighten clutch by turn counter clockwise as it is reverse threaded.
    • * You don't need to over tighten as the use of the blender will cause the clutch to tighten.
  9. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Insert plastic guard support: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the correct side up.
  10. Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Connect power cord and base: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart Velocity Ultra Trio Blender Clutch Replacement, Connect power cord and base: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Connect power cord to base and tighten.
    • Tighten four screws and insert rubber feet.
    • Test blender and enjoy!
Brendan
crwdns2935283:012/14/22crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,464
