If you are having trouble turning on your Cuisinart TOA-60Fr, it could be the power cord. The steps in this guide will walk you through the process of replacing the power cord. This does necessitate some wire stripping ability as well as knowledge of hot and natural electoral wire.
Using a 25-hexagon head, unscrew these 7.31 mm three screws.
Using a Phillips #1 screwdriver, remove all these 7.31 mm screws.
Pull off the back.
Pick the grey stoppers out with a sprudger.
Using a Phillips #1 screwdriver, remove these three 11 mm screws.
Unscrew all of the 11.05 mm screws that connect the outer shell to the device.
Take the needle nose pliers and cut off the crimped-on-wire connectors.
Strip the wires back with wire strippers. Or carefully take the needle nose pliers and cut gently to only make a mark on the jacket and not the wires. Then pull with the pliers to remove the jacket.
Take the white, blue, and black wire together and push togther
Then take the pliers and twist them until they are all combined.
Crimp the wire connector with a crimper or pliers
