Cuisinart Griddler GR- 4N Button Spring Replacement
    1. Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
      • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
    2. Cuisinart Griddler GR- 4N Button Spring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
    3. Cuisinart Griddler GR- 4N Button Spring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
    4. Cuisinart Griddler GR- 4N Button Spring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the single 5.5 mm Phillips #2 screw next to center black button.
      • After removing the center screw the metal plate should be free to remove.
    5. Cuisinart Griddler GR- 4N Button Spring Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart Griddler GR- 4N Button Spring Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
      • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
      • The aligned parts will allow the cooking surfaces to work properly.
    1. Cuisinart Griddler GR- 4N Button Spring Replacement, Button Spring: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Depress one of the gray tabs on the side of the housing.
    2. Cuisinart Griddler GR- 4N Button Spring Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull out the black button and the spring will also come out within it.
    3. Cuisinart Griddler GR- 4N Button Spring Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull out the spring, and insert the replacement spring making sure it is correctly aligned.
Laine Aro
crwdns2935283:004/11/16crwdne2935283:0
173 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-12, Maness Spring 2016 crwdns2935289:0Cal Poly, Team 1-12, Maness Spring 2016crwdne2935289:0
CPSU-MANESS-S16S1G12
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 131
crwdns2942667:0crwdne2942667:0 4,837
