Remove the small pusher by rotating it clockwise and lifting up.
Remove the large pusher by grabbing its sides and pulling up.
Remove the lid from the bowl by turning it clockwise and lifting.
Take out the blades by grabbing the plastic center piece and lifting up.
Position the handle of the bowl so that it is on your left.
Grab the handle and push clockwise. Lift up the bowl to remove it.
Turn the food processor's base upside down by lifting it up and turning it over.
Position the base so that the on and pulse buttons are facing you.
Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
Lift off the back casing by raising it upward.
