Cuisinart DCC-1200 Coffee Carafe Handle Replacement
  1. Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge the metal spudger between the plug and the handle.
    • Carefully pry the plug with the metal spudger by applying pressure around the plug.
    • Too much pressure and prying can damage the plug.
  2. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the bit driver with the Phillips PH1 bit to remove the 27 millimeter long screw in the base of the handle.
  3. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up on and remove the lid from the carafe.
  4. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Position the metal spudger underneath the top cap of the handle.
    • Gently pry up to extract the upper assembly cap.
    • Pry carefully to prevent from causing aesthetic damage to upper assembly cap.
  5. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the bit driver with the Phillips PH1 to remove the 5 millimeter screw in upper assembly of handle.
    • Remove handle by lifting straight up.
Austin Wheaton
crwdns2935283:002/15/18crwdne2935283:0
897 crwdns2915208:0crwdne2915208:0
UW Stout, Team S8-G1, Ogden Spring 2018 crwdns2935289:0UW Stout, Team S8-G1, Ogden Spring 2018crwdne2935289:0
UWSTOUT-OGDEN-S18S8G1
I needed this guide after my spouse put the carafe in the dishwasher and the handle sloshed no matter how much I shook it. It turns out water is easily trapped under the top cap; even though there's a drain hole into the handle, it doesn't seem to want to drain. I've wiped it off and left it to dry completely before reassembling it.
Max - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 4,488
