This guide will help you replace the selection knob of the Cuisinart DCC-1100. Please have a replacement knob ready and unplug the machine before beginning work.
Remove the coffee pot.
Open the lid.
Remove the two 1.6mm Phillips #1 screws from the lid.
Remove the lid from the coffee maker.
Remove the two 1.3mm screws from the display.
Push the display into the maker so that way you can access the screws in the back.
Remove the four 1mm Phillips #0 screws from the back.
Remove the back panel.
Remove the front panel from the display.
Remove the three 1mm Phillips #0 screws from the knob.
Remove the knob from the front panel.
Remove the plastic ring from the knob.
