Cuisinart DCC-1100 Hot Plate Replacement
  1. Cuisinart DCC-1100 Hot Plate Replacement, Hot Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the coffee maker.
  2. Cuisinart DCC-1100 Hot Plate Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the coffee pot and place the coffee maker upside down.
  3. Cuisinart DCC-1100 Hot Plate Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 1.6mm Phillips #1 screws from the bottom panel.
  4. Cuisinart DCC-1100 Hot Plate Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom panel.
  5. Cuisinart DCC-1100 Hot Plate Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 1.6mm Phillips #0 screws from the retaining bracket on the heating element.
  6. Cuisinart DCC-1100 Hot Plate Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the retaining bracket and allow it to hang off of the heating element.
  7. Cuisinart DCC-1100 Hot Plate Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hot plate from the heating element.
    • New thermal paste should be applied at time of installation.
crwdns2935229:05crwdne2935229:0
Josh Harvey
crwdns2935283:001/25/18crwdne2935283:0
910 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S20-G4, Passmore Spring 2018 crwdns2935289:0USF Tampa, Team S20-G4, Passmore Spring 2018crwdne2935289:0
USFT-PASSMORE-S18S20G4
crwdns2935297:020crwdne2935297:0
crwdns2947412:013crwdne2947412:0
thank you for this informative display.
I have broken many expensive glass carafs for my cuisinart coffeemaker and finally purchased a cuisinart thermal caraf.
I do not need the hotplate to heat, so what do I do to stop the heating process?
I imagine I would need to remove one of the attached lines to the heating element, yes?
Thanks.
Luciano
luciano1213@msn.com
Luciano Muzzatti - crwdns2934203:0crwdne2934203:0
Hi, Thanks for sharing this information. I have an older Krups coffee maker that still works great but the hot plate is warn. I cannot seem to find a replacement plate for any Krups coffee maker models. Any suggestions? Thanks!
Paulette Paglia - crwdns2934203:0crwdne2934203:0
Josh
where do I buy the replacement hot plate?? I have the sis 15 coffeemaker and I have googled all over the place?? Thank u
linkev428 - crwdns2934203:0crwdne2934203:0
Yes, where do you buy the part??
Kathy Johnston - crwdns2934203:0crwdne2934203:0
Yes my question is where do you get the new hot plate? Any direction appreciated.
DougB - crwdns2934203:0crwdne2934203:0
I replaced hot plate with a stainless steel disk bought on Amazon 1/8” thick and 4 1/2” diameter $5 plus shipping. Works a charm.
Peter - crwdns2934203:0crwdne2934203:0
Thanks--great tip! Did you use thermal paste? What is it--the heat sink compound used in PCs, or something else? Thanks!
Jan Pendleton -
where do i buy thermal paste?
jeanna - crwdns2934203:0crwdne2934203:0
where do i buy thermal paste? and the security screw driver?
Nice instructions.
Where do you buy the part/heating plate? I am a good googler. I cannot find a coffee maker heatplate.
Thanks
vizios5vizios5vizios5@gmail.com
fixroxie - crwdns2934203:0crwdne2934203:0
What is thermal paste? Is it the same substance used in PCs as a heat sink?
Jan Pendleton - crwdns2934203:0crwdne2934203:0
My question as well, where do you find the CORRECT hotplate for Cuisinart SS-15P1???
Mouse - crwdns2934203:0crwdne2934203:0
Did you get response w/ information? I also need same to replace my Cuisinart hot plate. Kindly provide. Thanks
P Colbert - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 6,821
