This guide will help you replace the hot plate of the Cuisinart DCC-1100. Please have a replacement hot plate ready for the installation and unplug the machine before beginning work.
Remove the coffee pot and place the coffee maker upside down.
Remove the five 1.6mm Phillips #1 screws from the bottom panel.
Remove the two 1.6mm Phillips #0 screws from the retaining bracket on the heating element.
Remove the retaining bracket and allow it to hang off of the heating element.
Remove the hot plate from the heating element.
crwdns2935229:05crwdne2935229:0
crwdns2947412:013crwdne2947412:0
thank you for this informative display.
I have broken many expensive glass carafs for my cuisinart coffeemaker and finally purchased a cuisinart thermal caraf.
I do not need the hotplate to heat, so what do I do to stop the heating process?
I imagine I would need to remove one of the attached lines to the heating element, yes?
Thanks.
Luciano
luciano1213@msn.com
Hi, Thanks for sharing this information. I have an older Krups coffee maker that still works great but the hot plate is warn. I cannot seem to find a replacement plate for any Krups coffee maker models. Any suggestions? Thanks!
Josh
where do I buy the replacement hot plate?? I have the sis 15 coffeemaker and I have googled all over the place?? Thank u
Yes, where do you buy the part??
Yes my question is where do you get the new hot plate? Any direction appreciated.
I replaced hot plate with a stainless steel disk bought on Amazon 1/8” thick and 4 1/2” diameter $5 plus shipping. Works a charm.
Thanks--great tip! Did you use thermal paste? What is it--the heat sink compound used in PCs, or something else? Thanks!
where do i buy thermal paste?
where do i buy thermal paste? and the security screw driver?
Nice instructions.
Where do you buy the part/heating plate? I am a good googler. I cannot find a coffee maker heatplate.
Thanks
vizios5vizios5vizios5@gmail.com
What is thermal paste? Is it the same substance used in PCs as a heat sink?
My question as well, where do you find the CORRECT hotplate for Cuisinart SS-15P1???
Did you get response w/ information? I also need same to replace my Cuisinart hot plate. Kindly provide. Thanks
