Cuisinart DCC-1100 Drip Spring Replacement
  1. Cuisinart DCC-1100 Drip Spring Replacement, Drip Spring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the coffee maker.
  2. Cuisinart DCC-1100 Drip Spring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the coffee pot and open the top lid.
  3. Cuisinart DCC-1100 Drip Spring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart DCC-1100 Drip Spring Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the basket filter holder.
  4. Cuisinart DCC-1100 Drip Spring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the basket filter from the holder.
  5. Cuisinart DCC-1100 Drip Spring Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press up on the drip spring mechanism.
  6. Cuisinart DCC-1100 Drip Spring Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart DCC-1100 Drip Spring Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While pressing up on the drip spring mechanism, remove the clear round plastic retainer holding the mechanism in place.
    Where can I purchase a replacement for that small gasket that holds the plunger in place
    Debra Auman - crwdns2934203:0crwdne2934203:0
  7. Cuisinart DCC-1100 Drip Spring Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the spring from the dripper.
    I have Cuisinart's Grind & Brew machine and it has an identical drip plug assembly. My problem was not knowing how to replace this spring, but having lost it and needing to find a suitable spring to replace. There are several spring specialty websites, but the one that had the item I needed had a $40 minimum. I measured carefully with a caliper and arrived at this spring size: 12 mm OD, 0.5 mm wire diameter, 30 mm free length. https://www.amazon.com/uxcell-0-5mmx12mm...
    Chris Rockett - crwdns2934203:0crwdne2934203:0
crwdns2935229:08crwdne2935229:0
Josh Harvey
crwdns2935283:001/25/18crwdne2935283:0
910 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S20-G4, Passmore Spring 2018 crwdns2935289:0USF Tampa, Team S20-G4, Passmore Spring 2018crwdne2935289:0
USFT-PASSMORE-S18S20G4
crwdns2935297:020crwdne2935297:0
Where do you find replacement springs?
Mrich - crwdns2934203:0crwdne2934203:0
I have Cuisinart's Grind & Brew machine and it has an identical drip plug assembly. I measured carefully with a caliper and arrived at this spring size: 12 mm OD, 0.5 mm wire diameter, 30 mm free length. https://www.amazon.com/uxcell-0-5mmx12mm...
Chris Rockett -
My basket holder has thrown off the clear plastic retainer ring; is there a replacement part I can purchase?
Raymond Classen - crwdns2934203:0crwdne2934203:0
When the basket holder came apart - the clear plasted retainer ring came off of mine, also. Can you just purchase this piece?
ncrenshaw4 - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 111
crwdns2942667:0crwdne2942667:0 12,401
