Turn the device upside down.
Remove all four rubber feet by prying them out using the metal spudger.
Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
Remove the base from the body of the blender.
Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver.
Gently move the wire aside so that it is not in the way.
Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
Gently remove the black cover.
Underneath, you will see a clear plastic cover that should be removed as well.
Cut the zip tie that holds the black, blue, red, and yellow wires together.
Remove the 2 black, yellow, and red wires from circuit board by push down on the tab to release and then pull up.
Pinch perpendicular to the flat surface and pull out the black wire.
