Cuisinart CHW-12 Water Hoses Replacement
  1. Cuisinart CHW-12 Water Hoses Replacement, Water Hoses: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart CHW-12 Water Hoses Replacement, Water Hoses: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the Coffee-maker from the power source.
    • Use a Phillips head screwdriver to remove the four 7mm screws from the back and the three 8mm screws from the bottom. This will release the bottom cover.
  2. Cuisinart CHW-12 Water Hoses Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart CHW-12 Water Hoses Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the two rubber feet marked within the provided pictures.
    • Remove both 8mm Phillips head screws found within the holes where the feet were just removed.
  3. Cuisinart CHW-12 Water Hoses Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart CHW-12 Water Hoses Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart CHW-12 Water Hoses Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull the cover off the bottom of the coffee maker. This will give you access to the inside of the coffee maker.
    • Remove the two 10mm screws with a Phillips head screwdriver.
    • Position the heating coil connected to the hose for easier access to the clamps.
    • Beware of grey silicone. This paste is nontoxic to the touch but is poisonous if consumed.
  4. Cuisinart CHW-12 Water Hoses Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart CHW-12 Water Hoses Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze the two hose clamps together as you slide the clamps away from the heating element.
    • After the clamped are cleared of the heating element, gently remove the hoses from the coil.
  5. Cuisinart CHW-12 Water Hoses Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart CHW-12 Water Hoses Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart CHW-12 Water Hoses Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Squeeze the clamp on the opposite end of the hose(s) that need replacement.
    • Once the clamp is free on the opposing end, gently pull the hose upwards to remove it.
    • Replace the disconnected hose with a new functional hose.
Trevor Aspinall
crwdns2935283:003/22/18crwdne2935283:0
367 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team S17-G2, Blackburne Spring 2018 crwdns2935289:0Sam Houston State, Team S17-G2, Blackburne Spring 2018crwdne2935289:0
SHSU-BLACKBURNE-S18S17G2
crwdns2947412:08crwdne2947412:0
Um, you forgot a MAJOR detail; there is a ball valve backflow preventer in the existing hose, which MUST be transferred into the replacement hose.
If it is not replaced, the coffe machine will NOT WORK. - You are welcome.
Ken Askildsen - crwdns2934203:0crwdne2934203:0
Nice Ken, very nice….Thank you!!
John - crwdns2934203:0crwdne2934203:0
Where can I purchase the hoses?
Rob - crwdns2934203:0crwdne2934203:0
Also, the measurements for the hose ID and OD are incorrect. The ID is at least 10 mm. I tried using the measurements you gave, which translate to 8mm ID x 12 mm OD, and that is way too small. The check valve will NOT fit into this smaller diameter tubing. The check valve body itself is 10mm in diameter. I ordered some of the size you listed and it is easily seen without measuring that the tubing doesn't come close to matching.
jefftuckercfii - crwdns2934203:0crwdne2934203:0
Oh My....I don't understand Mr. Fixya's numbers to begin with. So, not 10mm or 12mm. can you tell me what mm these should be and possibly where I could find them? My beautiful CHW-12....is now at an insane $185. What a blessing to hear that this can be repaired! thankyou soooo much xo
Carol Halpin -
crwdns2936753:030crwdne2936753:0 66
crwdns2942667:0crwdne2942667:0 3,911
