Cub Cadet Z-Force 48 Oil Change
  1. Cub Cadet Z-Force 48 Oil Change, Cub Cadet Z-Force 48 Oil Change: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, ensure the mower is turned off, the engine has cooled, and it is in park.
    • Place the drain pan under the drain.
  2. Cub Cadet Z-Force 48 Oil Change: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cub Cadet Z-Force 48 Oil Change: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cub Cadet Z-Force 48 Oil Change: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the tip of the oil drain hose with the closed end of a 3/4-inch combination wrench.
    • Use the open end of the 1/2 inch combination wrench to loosen the oil drain plug.
    • Finish loosening the drain plug with your hands and remove it.
  3. Cub Cadet Z-Force 48 Oil Change: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let the oil drain into the drain pan.
  4. Cub Cadet Z-Force 48 Oil Change: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cub Cadet Z-Force 48 Oil Change: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cub Cadet Z-Force 48 Oil Change: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reinsert the drain plug and tighten it with the open end of a 1/2-inch combination wrench.
    • Use a torque wrench to tighten 13.6 N·m (10 ft. lb.).
    • Refer to your owner's manual to ensure the correct tightness of the drain plug.
  5. Cub Cadet Z-Force 48 Oil Change: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cub Cadet Z-Force 48 Oil Change: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cub Cadet Z-Force 48 Oil Change: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place paper towels or an old rag under the old oil filter to catch any excess oil.
    • Remove the old oil filter.
    • If the oil filter is too tight, use oil filter pliers to loosen before removal.
  6. Cub Cadet Z-Force 48 Oil Change: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the soiled paper towels underneath the oil filter mount.
    • Wipe the oil filter mount clean with paper towels.
  7. Cub Cadet Z-Force 48 Oil Change: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your finger to place a thin film of clean oil on the O-ring of the new oil filter.
  8. Cub Cadet Z-Force 48 Oil Change: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cub Cadet Z-Force 48 Oil Change: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Install the new oil filter, hand tightening the filter clockwise.
    • Tighten the oil filter until the rubber gasket contacts the oil filter mount, then tighten an additional 3/4-1 turn.
    • Refer to your owner's manual to ensure the correct tightness of the oil filter.
  9. Cub Cadet Z-Force 48 Oil Change: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cub Cadet Z-Force 48 Oil Change: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cub Cadet Z-Force 48 Oil Change: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the oil fill cap.
    • Fill the engine with the amount and type of oil specified in your owner's manual.
    • Put the oil fill cap back into place.
    • For this mower, any service class SG, SH, SJ, or higher oil can be used.
  10. Cub Cadet Z-Force 48 Oil Change: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start the engine and check for leaks.
    • Stop the engine and allow the oil to drain down.
    • Remove the oil fill cap and check the dipstick to ensure that the oil is to the full mark.
Please check your local regulations to ensure proper disposal of oil.
Lauren Daniel
crwdns2935283:004/05/23crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 159
