Replace the speakers to improve the sound quality of your device.
Using a Phillips #00 Screwdriver, take out the following screws:
Two 6 mm screws
Three 4 mm screws
Four 3 mm screws
Using a Phillips #00 Screwdriver, remove the screws located under the top two standoffs.
Remove the cover off the back of the device.
Two speakers can be found on the device, one in the lower-right corner and one in the lower left-corner.
Gently pull up on the speaker to remove it. Repeat this for the other speaker.
De-solder the red and black wires to disconnect the old speaker.
Follow the How To Solder and Desolder Connections guide for help.
