Crosley CR42 Power Cable Replacement
  1. Crosley CR42 Power Cable Replacement, Power Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Crosley CR42 Power Cable Replacement, Power Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the device around until you are looking at the line-out port.
    • With a cordless drill or Phillips #0 screwdriver, remove the ten 12-mm screws.
  2. Crosley CR42 Power Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crosley CR42 Power Cable Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crosley CR42 Power Cable Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the back of the device. It should be connected by two wires.
  3. Crosley CR42 Power Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crosley CR42 Power Cable Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crosley CR42 Power Cable Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove both wires.
    • After de-threading the antenna wire, remove the back of the device and set it aside.
  4. Crosley CR42 Power Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crosley CR42 Power Cable Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crosley CR42 Power Cable Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate where the power cable connects to the device.
    • Pick up the device and locate the screw holding the small black peg to the device. Unscrew it and set the screw aside.
  5. Crosley CR42 Power Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crosley CR42 Power Cable Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crosley CR42 Power Cable Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the pliers, remove the wire connectors. You may need to be forceful
    • It is wise to attach a marking in order to recognize how the wires should be reattached.
  6. Crosley CR42 Power Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crosley CR42 Power Cable Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crosley CR42 Power Cable Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull apart both groups of wires.
    • After getting your replacement power cord, make sure you recognize how the wires should reattach.
  7. Crosley CR42 Power Cable Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crosley CR42 Power Cable Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crosley CR42 Power Cable Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Twist the connecting wires together.
    • Attach the twist-on wire connectors to the exposed wires.
Eric Dybsetter
crwdns2935283:001/26/14crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-38, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 1-38, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S1G38
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 6,920
