Crosley CR42 Bushings Replacement
  1. Crosley CR42 Bushings Replacement, Bushings: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Crosley CR42 Bushings Replacement, Bushings: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the device around so the line out port faces you.
    • Remove the ten 12 mm screws with the Phillips screwdriver.
  2. Crosley CR42 Bushings Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crosley CR42 Bushings Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crosley CR42 Bushings Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the line out port toward you so you can view the inside of the Crosley.
    • Locate the wires that connect the line out port to the inside of the device.
  3. Crosley CR42 Bushings Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crosley CR42 Bushings Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crosley CR42 Bushings Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull on the two connections to remove them from the back of the line out port.
    • Remove the antenna wire from the line out port, then remove the line out port and set it aside.
  4. Crosley CR42 Bushings Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Crosley CR42 Bushings Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the red and black connection underneath the turntable.
  5. Crosley CR42 Bushings Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Position yourself in front of the turntable to unscrew the three bushing bolts.
  6. Crosley CR42 Bushings Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crosley CR42 Bushings Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crosley CR42 Bushings Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the three bushing bolts with the Phillips screw driver.
  7. Crosley CR42 Bushings Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Crosley CR42 Bushings Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the turntable out from the casing.
    • Remove the three bushing bolts.
  8. Crosley CR42 Bushings Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crosley CR42 Bushings Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crosley CR42 Bushings Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pinch the rubber bushing at the bottom, then pull downwards to remove it.
    • Repeat the previous step for the other two bushings.
Roberto Rosila
crwdns2935283:001/26/14crwdne2935283:0
328 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-38, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 1-38, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S1G38
crwdns2942667:0crwdne2942667:0 3,240
