Crosley CR42 Band Replacement
  1. Crosley CR42  Band Replacement, Band: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check troubleshooting wiki to make sure you aren't doing way more work than you have to!
    • If you believe the band may be broken or out of place, start by unplugging the record player.
  2. Crosley CR42  Band Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Crosley CR42  Band Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the needle is in its resting position off to the side.
    • Gently remove the turntable from the device by lifting it directly upward.
  3. Crosley CR42  Band Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the band, it may have fallen into the inside of the record player as you removed the turntable.
    • Inspect your band for any tears, rips, or obvious signs of stretching.
  4. Crosley CR42  Band Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the turntable over.
    • Locate the notch on the back side of the turntable.
    • The notch will be on the outside edge of the turntable.
  5. Crosley CR42  Band Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Crosley CR42  Band Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wrap the band around the inner circle of the turntable and gently pull the band until you get to the notch.
    • Loop the band around the notch, the band should be taut.
  6. Crosley CR42  Band Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Crosley CR42  Band Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the turntable back onto the device.
    • Make sure to line up the band with the turning knob, to ensure the band is properly placed.
  7. Crosley CR42  Band Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the turntable is back on the device, gently turn it clockwise until you hear a 'click.'
    • Job well done!
Roberto Rosila
crwdns2935283:001/26/14crwdne2935283:0
328 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-38, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 1-38, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S1G38
My CR42 has a plastic piece that will not let me simply pull the turntable off. I don't want to try to hard to break it, but I also don't know how to get it off to replace the band.
athena - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,116
