Crock-Pot Express Crock Multi-Cooker Heating Element Replacement
  1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Power Cord: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the power cord from the wall outlet first, disconnecting power from the device.
  2. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the device with with the LED facing away from the user allowing access to the input jack of the power cord.
  3. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the power cord input connector firmly with forefinger and thumb.
    • Without tugging, apply pulling force until the connector is free from device
    I want just the electric cord only that’s work on Crock-Pot 6 qt thank you
    Le White - crwdns2934203:0crwdne2934203:0
  4. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the crock pot where the lid locked and unlocked icons are visible.
    • Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
    • Remove the lid.
    Bobber Valve Gasket
    SKU: SAP_196077000000
    link no longer works because 10qt piece discontinued. They are shipping me valve for 8qt lid to see if it works. I have attached part number for 8 qt bobber valve gasket.
    Thanks
    Bo Peep - crwdns2934203:0crwdne2934203:0
  5. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Heating Element: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the inner pot and set it aside for reassembly.
  6. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully rotate the Crock-Pot so that the bottom is facing upward, allowing access to the electrical panel.
    • Remove the two 12.4 mm screws with a Phillips #2 screwdriver.
  7. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the electrical panel cover counter clockwise and pull up until the panel comes free.
  8. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 3 nuts, 3 washers, 3 spacers, and 3 lock washers using an adjustable wrench to free the heating element from the Crock-Pot housing.
  9. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 10mm screw and metal plate beneath the electrical nodes using a Phillips #2 screwdriver.
  10. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 red wires from the terminal post by unscrewing the 10mm screw using a Phillips #2 screwdriver and label terminal post as red.
    • Remove 1 white wire from terminal post by unscrewing the 10mm screw using a Phillips #2 screwdriver and label terminal post as white.
  11. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reorient the crockpot on its side to prepare for the heating element removal.
  12. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the heating element out and rotate it until bottom side is facing up out of the pot.
  13. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove both 19mm screws from the cutout switch housing using a Phillips #2 screwdriver, freeing the heating element from the device.
    • Carefully remove the heating element from the device.
    The screws have been replaced with triwng screws but found torc t7 works fine.
    Parker, C - crwdns2934203:0crwdne2934203:0
William Kelly
crwdns2935283:009/24/18crwdne2935283:0
817 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S3-G9, Eggleston Fall 2018 crwdns2935289:0The Citadel Military College of South Carolina, Team S3-G9, Eggleston Fall 2018crwdne2935289:0
CMCSC-EGGLESTON-F18S3G9
where do you get a heating element?
Stephanie Brown - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,137
