Cricut Explore Air 2 Roller Bar Replacement
  1. Cricut Explore Air 2 Roller Bar Replacement, Front Door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Explore Air 2 Roller Bar Replacement, Front Door: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On both the left and right sides of the Cricut, locate the two internal screws.
    • Use a Phillips #1 screwdriver bit to unscrew the top 10.8 mm screw and the lower 9.1 mm screw on each side, four screws in total.
  2. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the Cricut so the bottom faces upwards.
  3. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the four screws, two on the left and two on the right, with pads attached.
    • Using a Phillips #2 screwdriver, remove all four of the screws and their pads.
  4. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the Cricut back to an upright position.
  5. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the left and right sides of the Cricut's plastic shell off.
  6. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the right side of the Cricut, locate the circuit board screwed in to the cover just removed.
    • Locate the four screws securing the circuit board to the shell.
    • Use a Phillips #1 screwdriver to unscrew each of the four 10 mm screws.
  7. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently unplug the connector from the circuit board, freeing the right side of the plastic shell completely.
  8. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On both the left and right sides of the back plastic panel.
    • Using a Phillips #2 screwdriver, unscrew each of the four 5mm screws.
  9. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge a plastic pryer tool next to the left side of the back panel.
    • Gently pry the left side of the back door from the rest of the machine.
    • Repeat with the right side of the back door to completely remove the back panel.
  10. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On both the left and right sides, locate the screws securing the top door's hinge.
    • Use a Phillips #1 screwdriver to remove the two 6.5 mm screws on each side, four in total.
  11. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the lid off of the Cricut.
  12. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the screws on the corners of the metal interior plate on both the left and right sides.
    • Unscrew the two the 8 mm screws on each side, four in total.
  13. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lean the metal interior and all that comes with it backwards, exposing the bottom plastic shell of the Cricut.
  14. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the screws securing the front door hinge to the bottom plate of the Cricut.
    • Unscrew each of the four 5 mm screws on each side, 8 in total.
  15. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the front door from the bottom plate of the Cricut.
  16. Cricut Explore Air 2 Roller Bar Replacement, Roller Bar: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the spring on the left side of the Cricut's metal interior frame.
    • Gently remove the spring by disconnecting the hooks on either side.
    • Repeat on the right side.
  17. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify the metal piece holding the roller bar in place.
    • Wedge a prying tool underneath the metal to free the interior from this piece of the frame.
  18. Cricut Explore Air 2 Roller Bar Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently push the metal frame, skewing it to free the roller bar.
    • Do not push too hard or too quick, as you risk breaking the frame.
    • Repeat on the right side to fully free the roller bar.
Hannah Vanvlack
crwdns2935283:001/23/24crwdne2935283:0
875 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-1, Virtue Spring 2024 crwdns2935289:0Western Carolina University, Team 1-1, Virtue Spring 2024crwdne2935289:0
WCU-VIRTUE-S24S1G1
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 80
crwdns2936753:030crwdne2936753:0 252
crwdns2942667:0crwdne2942667:0 2,292
