Cricut Explore Air 2 Roller Bar Motor Replacement
  1. Cricut Explore Air 2 Roller Bar Motor Replacement, Roller Bar Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Explore Air 2 Roller Bar Motor Replacement, Roller Bar Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the Cricut open, access the two internal screws on the front left side.
    • Use the Phillips #1 screwdriver to remove the top 10.82 mm screw and the bottom 9.1 mm screw.
  2. Cricut Explore Air 2 Roller Bar Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Explore Air 2 Roller Bar Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the Cricut so the bottom is facing upwards.
    • Identify the two screws with pads.
    • Using the Phillips #2 screwdriver, remove both 42.77 mm screws.
  3. Cricut Explore Air 2 Roller Bar Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the Cricut back to its upright position.
    • Gently lift the cover on the left side of the machine to reveal the parts underneath.
  4. Cricut Explore Air 2 Roller Bar Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cricut Explore Air 2 Roller Bar Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the circuit board on the cover just removed.
    • Use the Phillips #1 screwdriver to unscrew each of the four 10 mm screws.
  5. Cricut Explore Air 2 Roller Bar Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently unplug the connector, removing the circuit board.
  6. Cricut Explore Air 2 Roller Bar Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently unplug the connector located on the roller bar motor.
  7. Cricut Explore Air 2 Roller Bar Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the three screws securing the plate holding the roller bar motor to the Cricut.
    • Use the Phillips #1 screwdriver to remove each of the three 5 mm screws.
  8. Cricut Explore Air 2 Roller Bar Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor from the interior of the Cricut.
  9. Cricut Explore Air 2 Roller Bar Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the white gear from the roller bar motor.
  10. Cricut Explore Air 2 Roller Bar Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the two screws holding the roller bar motor to the mounting plate.
    • Use the Phillips #1 screwdriver to remove the two 2 mm screws.
  11. Cricut Explore Air 2 Roller Bar Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor from the plate.
Hannah Vanvlack
crwdns2935283:001/23/24crwdne2935283:0
875 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-1, Virtue Spring 2024 crwdns2935289:0Western Carolina University, Team 1-1, Virtue Spring 2024crwdne2935289:0
WCU-VIRTUE-S24S1G1
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 509
