Creative Ziio 7" Motherboard Replacement
  1. Creative Ziio 7" Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Creative Ziio 7" Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Creative Ziio 7" Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" Motherboard Replacement, Motherboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Creative Ziio 7" Motherboard Replacement, Motherboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Creative Ziio 7" Motherboard Replacement, Motherboard: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the copper plate covering the motherboard by desoldering the ten solder points.
    • The solder point in the bottom right corner is marked but hidden by the soldering iron.
  3. Creative Ziio 7" Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Creative Ziio 7" Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the adhesive tape covering the three wires connected to the motherboard.
    • Desolder the solder points connecting the wires to the motherboard.
  4. Creative Ziio 7" Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Creative Ziio 7" Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Creative Ziio 7" Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the ribbon cable that is attached underneath the copper plate.
    • Disconnect the other ribbon cable that is connected next the copper plate in the corner of the circuit board.
  5. Creative Ziio 7" Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Creative Ziio 7" Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 4mm Philips #00 screws holding the motherboard to the casing.
    • The copper plate will be removed by now. However, the picture does not show this.
  6. Creative Ziio 7" Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Creative Ziio 7" Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the motherboard.
    • A mesh-looking strip on the left side will be connected to the bottom of the motherboard.
    • Remove the tape on top of the strip and use tweezers or pliers to pull on the strip to unplug it.
  7. Creative Ziio 7" Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the red and black wires with a soldering iron that are located underneath the motherboard.
    • Do not cut or damage the wires in the process. They will be needed for the new motherboard.
  8. Creative Ziio 7" Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the old motherboard and dispose of it resposibly.
Benedict Samoy
crwdns2935283:004/16/13crwdne2935283:0
25 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-10, Maness Spring 2013 crwdns2935289:0Cal Poly, Team 14-10, Maness Spring 2013crwdne2935289:0
CPSU-MANESS-S13S14G10
crwdns2935297:013crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,286
