Creative Zen Vision W LCD Screen Replacement
crwdns2942287:0crwdne2942287:0This guide will show you how to remove and install a new LCD screen in your device. Use this guide if your screen is broken or damaged and needs to be replaced.
crwdns2944105:0crwdne2944105:0
Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
Run the spudger along the cover and pry.
The button pad may fall off when the cover is removed.
Use a spudger to separate the metal tabs that hold the screen in place on the right side.
Put the screen face down so you can see where the ribbon cables are attached.
Remove the red sticker that covers the ribbon cable connections.
Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
Remove the screen from the device.
Where can I get the screen
