Creative Zen V Plus Battery Replacement
  1. Creative Zen V Plus Battery Replacement, Prerequisite Only: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Creative Zen V Plus Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
    There are two (2) screws on the Zen V Plus 8 GB
    John Herlihy - crwdns2934203:0crwdne2934203:0
  6. Creative Zen V Plus Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Creative Zen V Plus Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Creative Zen V Plus Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Simply unplug the white colored battery from it's terminal and replace with the new battery.
    • This completes the battery replacement process. Well done!
    I have 2 of these, a 2 GB green one and a 4 GB blue one. Both of these have 2 small + & - pads where you show a handy plug that the battery wires are soldered. These +/- pads are very close together and require you to have pretty steady hands and good soldering technique to replace the battery.
    Ryan Blomquist - crwdns2934203:0crwdne2934203:0
crwdns2935229:09crwdne2935229:0
Brock Schaffer
crwdns2935283:010/26/16crwdne2935283:0
499 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-5, Baechle Fall 2016 crwdns2935289:0IUPUI, Team 2-5, Baechle Fall 2016crwdne2935289:0
IUPUI-BAECHLE-F16S2G5
This is a good guide as it applies to the Zen V Plus used. My Zen V Plus, however, had a few differences: 1. my Zen’s original battery is soldered to the PCB, there is no plug. So unless the person replacing the battery is experienced at soldering the possibility for damage is very high. This board is very small and it would be very easy to damage this board with a soldering iron; 2. The battery in my unit wasn’t laying loose in the bottom of the unit it was held in with double sided tape. It was a thin, clear double sided tape that looks like ordinary scotch tape. It had a pretty good bond but it was broken fairly easily. Just treat it like everything else in the unit and be as gentle as possible. There is one more thing to be aware of; Pay close attention to the alignment of the slider (for power) to the wiper of the switch it goes to. It can be real annoying to have it all back together and then it won’t turn on.
rchilders11 - crwdns2934203:0crwdne2934203:0
Replace battery. Still, saying weak battery. ???? Change cord. Still. Weak battery. ????
bobn_sheraton - crwdns2934203:0crwdne2934203:0
WHERE CAN I BUY A REPLACEMENT BATTERY? I’m in South Africa
boland - crwdns2934203:0crwdne2934203:0
Replacement batteries can be found on eBay.com. Just search on the number that is on your battery (e.g. creative ba20603r79919 battery). You can also use generic replacements, but make sure that it has similar or higher capacity, and that the dimensions are similar as your current battery.
Peter - crwdns2934203:0crwdne2934203:0
What if i use a 500mah battery will it di??
5skimov lolz - crwdns2934203:0crwdne2934203:0
Hi,
I hope this reaches you somehow, as I’ve looked everywhere i could on the internet but failed to find an answer. Is there any way to fix the screen if it got unplugged? Apparently I used too much force…
Will be waiting for your feedback. Thanks and take care,
MM
Marivana - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 73
crwdns2942667:0crwdne2942667:0 10,087
