Create macOS USB Stick (El-Capitan - Ventura)
  1. Create macOS USB Stick (El-Capitan - Ventura), Load macOS installer: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To load the macOS installer you can use "ANYmacOS", this is a tool which allows you to create USB sticks for newer Macs on older Macs.
    • Download the program from here: https://www.sl-soft.de/anymacos/ . Requires macOS 10.13 High Sierra or newer.
    • Unarchive the program and copy the program to the Applications folder. If you get an error message when opening the program that it cannot be opened, then simply open it by right-clicking and then "Open".
  2. Create macOS USB Stick (El-Capitan - Ventura), Load macOS: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Under Select OS, choose the macOS you want to download.
    • Select one and then download.
    • You may be prompted later to enter your password. The installer should be in the Applications folder later.
    • On the right you can see your current OS version.
  3. Create macOS USB Stick (El-Capitan - Ventura), Delete USB stick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Create macOS USB Stick (El-Capitan - Ventura), Delete USB stick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Create macOS USB Stick (El-Capitan - Ventura), Delete USB stick: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The corresponding installation program should now be located in the Programs folder.
    • Now you have to format your USB stick with the Disk Utility. Insert a USB stick with at least 16 GB and open the Disk Utility either via Spotlight or via Launchpad.
    • Select under the item Appearance, Show all devices and then select your USB stick on the left.
    • Then select the item Erase. Select the following properties: Name: USB Format: Mac OS Extended (journaled) Scheme: GUID partition table
    • Save your data on the USB stick if you still need it. When you delete the data, it will be erased.
  4. Create macOS USB Stick (El-Capitan - Ventura), Create USB-Stick: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Create macOS USB Stick (El-Capitan - Ventura), Create USB-Stick: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Create macOS USB Stick (El-Capitan - Ventura), Create USB-Stick: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open ANYmacOS again if you have already closed it. Select the item Create Installer on the right.
    • Select the previously formatted USB-Stick at Select Volume and then select Start
    • In the next step you only have to select your installer, for this select Select and select your installer.
    • Finally select Start at the bottom. You will be prompted to enter your password so that the program can create the installer USB stick
    • After that the USB stick is created and you are ready to install macOS.
    • Creating the USB flash drive can take a different amount of time depending on the USB flash drive, system and USB port.
Your macOS USB stick has now been created.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
[deleted]
crwdns2935283:001/24/22crwdne2935283:0
2,993 crwdns2915208:0crwdne2915208:0
Ich möchte einen Installer USB-Stick für El Capitan erstellen, leider wird die OS Version 10.11 nicht in dem Programm ANY MacOS aufgeführt...?!
Anika - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 66
crwdns2936753:030crwdne2936753:0 180
crwdns2942667:0crwdne2942667:0 5,078
