Creality CR-10S Stepper Motor Dampener Replacement
  1. Creality CR-10S Stepper Motor Dampener Replacement, Stepper Motor Dampener: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the 3mm Allen key, remove the two 3mm Allen head screws on either side of the y-axis bracket to undo the tensioner. Push forward to give the belt slack.
  2. Creality CR-10S Stepper Motor Dampener Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Creality CR-10S Stepper Motor Dampener Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Creality CR-10S Stepper Motor Dampener Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the 2mm Allen key, remove the four 2mm Allen head screws holding the motor and set down with the gear wheel facing up.
    • Install the damper using two of the 2mm Allen head screws. Make sure that the wider opening of the dampener is facing the motor.
    • The two holes without threads go flush with the motor and the two holes with threads go flush against the plastic bracket.
  3. Creality CR-10S Stepper Motor Dampener Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Creality CR-10S Stepper Motor Dampener Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Creality CR-10S Stepper Motor Dampener Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reinstall the motor using the remaining two 2mm Allen head screws by mounting the damper onto the bracket.
    • Adjust the gear wheel by undoing the two 2mm Allen head screws, centering the wheel, and re-tightening the screws.
    • Once the gear wheel is centered, reinstall the belt.
  4. Creality CR-10S Stepper Motor Dampener Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tighten the belt by pulling on the tensioner bracket and tightening the two 3mm Allen head screws.
  5. Creality CR-10S Stepper Motor Dampener Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 3mm Allen head bolts on the x-axis tensioner and push the bracket toward motor to create slack on the belt.
  6. Creality CR-10S Stepper Motor Dampener Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Creality CR-10S Stepper Motor Dampener Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four 2mm Allen head bolts holding the motor and sensor to the chassis.
    • Undo the belt and remove the stepper motor from the mount.
  7. Creality CR-10S Stepper Motor Dampener Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Creality CR-10S Stepper Motor Dampener Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Creality CR-10S Stepper Motor Dampener Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You will have to hold the sensor cover and motor in place when performing this installation.
    • Install the damper onto the motor as explained in Step 2.
    • Ensure that the gear wheel is centered similarly to Step 3 before doing the final assembly.
    • Reinstall the motor onto the bracket by re-using two of the long 2mm Allen head screws.
  8. Creality CR-10S Stepper Motor Dampener Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tighten the belt by pulling on the tensioner bracket as you tighten the two 3mm Allen head screws.
Hugo G
crwdns2935283:010/23/20crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team S12-G23, Harris Fall 2020 crwdns2935289:0CSU Los Angeles, Team S12-G23, Harris Fall 2020crwdne2935289:0
CSULA-HARRIS-F20S12G23
crwdns2942667:0crwdne2942667:0 1,348
