Crankcase Opening Procedure
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Crankcase Opening Procedure, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Crankcase Opening Procedure, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, disconnect the spark plug connector from the spark plug.
  2. Crankcase Opening Procedure, Elevate the generator: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Elevate the generator on a set of stable risers, like wooden blocks.
    • Place a drain pan underneath the generator, between the blocks.
  3. Crankcase Opening Procedure, Drain the oil: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crankcase Opening Procedure, Drain the oil: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crankcase Opening Procedure, Drain the oil: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 12 mm socket to remove the oil drain plugs from either side of the generator.
    • Give the oil a few minutes to drain from the cylinder and crankcase housing.
    • Tip the generator back and forth towards either drain hole to allow any last bits of oil to drain.
    • Once the oil is finished draining, replace the drain plugs.
    • Tighten the drain plugs to 13 ft-lb (18 N-m) of torque.
    • During reassembly, be sure to refill the engine oil:
    • Use up to 0.58 liters of SAE 10W-30 oil, until the dipstick is almost completely submerged.
  4. Crankcase Opening Procedure, Remove the shaft guard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crankcase Opening Procedure, Remove the shaft guard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crankcase Opening Procedure, Remove the shaft guard: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 12 mm socket to remove the two 20 mm-long bolts securing the shaft guard to the crankcase cover.
    • Remove the shaft guard.
  5. Crankcase Opening Procedure, Unfasten the crankcase cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 12 mm socket to remove the six 32 mm-long bolts securing the crankcase cover.
    • During reassembly, tighten these bolts down to 17 ft-lb (24 N-m) of torque.
  6. Crankcase Opening Procedure, Unfasten the upper cylinder shroud: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crankcase Opening Procedure, Unfasten the upper cylinder shroud: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crankcase Opening Procedure, Unfasten the upper cylinder shroud: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 12 mm socket to remove the nut securing the upper cylinder shroud and air guide plate.
    • Use a 10 mm socket to remove the 12 mm-long bolt securing the air guide plate.
    • Remove the air guide plate.
  7. Crankcase Opening Procedure: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crankcase Opening Procedure: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crankcase Opening Procedure: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 10 mm socket to remove the 12 mm-long bolt securing the upper cylinder shroud.
    • Tilt the upper shroud upward slightly so the hook on the right of the shroud is free from the bolt.
    • You may need to bend the hook out of shape slightly to reposition the shroud like this.
    • If you do bend the hook, simply use a pair of pliers to bend it back into place before refastening the nut during reassembly.
  8. Crankcase Opening Procedure, Remove the crankcase cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crankcase Opening Procedure, Remove the crankcase cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crankcase Opening Procedure, Remove the crankcase cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When the shroud is sufficiently out of the way, remove the crankcase cover.
    • Residual oil may leak when you remove the cover. Be ready to catch any spillage.
Tarun Thiruma
crwdns2935283:011/20/19crwdne2935283:0
38,431 crwdns2915208:0crwdne2915208:0
crwdns2935297:0134crwdne2935297:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 23
