Craig Electronics CMP773 Screen Replacement
  1. Craig Electronics CMP773 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Craig Electronics CMP773 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two screws on the charging port side of the tablet using the Phillips #00 screwdriver.
  2. Craig Electronics CMP773 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Craig Electronics CMP773 Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Craig Electronics CMP773 Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening tool between the screen and the back of the tablet.
    • Insert another opening tool along the same side of the tablet and pry them in opposite directions until the casing pops.
    • Once roughly half of the case has been unlatched, it can be removed by hand.
  3. Craig Electronics CMP773 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Craig Electronics CMP773 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to gently pry the camera from the casing.
  4. Craig Electronics CMP773 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Craig Electronics CMP773 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your finger, remove the clamp that connects the screen power rib to the motherboard.
    • Using needle nose pliers, remove the ribbon.
  5. Craig Electronics CMP773 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Craig Electronics CMP773 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Craig Electronics CMP773 Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the second screen power connection from the motherboard using the same procedure as step 4.
  6. Craig Electronics CMP773 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Craig Electronics CMP773 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Craig Electronics CMP773 Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four screws from the motherboard using the Phillips #00 screwdriver.
  7. Craig Electronics CMP773 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Craig Electronics CMP773 Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove a single screw from the speaker using the Phillips #00 screwdriver.
    • Pry up on the locking tabs with the flat spudger.
  8. Craig Electronics CMP773 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using needle nose pliers, remove the ground wire from the casing.
  9. Craig Electronics CMP773 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, remove the battery.
  10. Craig Electronics CMP773 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Craig Electronics CMP773 Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With all screws and components removed, gently remove the motherboard from the casing.
  11. Craig Electronics CMP773 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Craig Electronics CMP773 Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Craig Electronics CMP773 Screen Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the spudger in between the screen and case. Work your way around the outside of the screen.
  12. Craig Electronics CMP773 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Craig Electronics CMP773 Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Craig Electronics CMP773 Screen Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp the exposed screen corner and gently separate the screen from the housing.
Justin mersch
crwdns2935283:011/07/19crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
IUPUI, Team S3-G4, Harley Fall 2019 crwdns2935289:0IUPUI, Team S3-G4, Harley Fall 2019crwdne2935289:0
IUPUI-HARLEY-F19S3G4
What kind of battery does this device specifically use
Kris Miller - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 301
