WARNING: Once the power cord has been identified as the item that needs replacement, make sure that the device is disconnected from any power supply.
Remove the two 1" Phillips screws using a #1 Phillips screwdriver.
Remove the three 1/2" Phillips screws using a #1 Phillips screwdriver.
Once the five screws are removed, lift the handle cover from the saw.
Remove the 1/2" Phillips screw that is securing the switch using a Phillips #1 screwdriver.
Using a Phillips #00 screwdriver or a small diameter screwdriver, gently insert it into the leads. When the screwdriver is inserted into the lead, it will release the wire.
Release both the black and white wires and gently pull them from the leads.
