Craftsman 944.360480 Carburetor O-Ring Replacement
  1. Craftsman 944.360480 Carburetor O-Ring Replacement, Carburetor O-Ring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure your engine is completely shut down and cooled off prior to starting this repair.
    • Put gloves on, so you don’t get any oil or gasoline on your skin.
  2. Craftsman 944.360480 Carburetor O-Ring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a flathead screwdriver and remove the 40 mm screw that secures the air filter and the case to the lawn mower.
  3. Craftsman 944.360480 Carburetor O-Ring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the air filter and set it aside.
  4. Craftsman 944.360480 Carburetor O-Ring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly remove the air filter case from the hinges by tilting it slightly and pulling it out.
  5. Craftsman 944.360480 Carburetor O-Ring Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the socket wrench and put the 5/16” inch hex bit on to remove the three 20 mm bolts located behind the air filter.
  6. Craftsman 944.360480 Carburetor O-Ring Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the plastic backing off which will expose the carburetor.
  7. Craftsman 944.360480 Carburetor O-Ring Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Craftsman 944.360480 Carburetor O-Ring Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use utility pliers to pull out the fuel line slowly by wiggling it up and down.
    • Have a container ready to pour out any extra fuel left in the mower.
    • Be sure to put a cloth or rag under if you don’t want it spilling anywhere.
  8. Craftsman 944.360480 Carburetor O-Ring Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the socket wrench with a ½” inch hex bit to remove the 11 mm screw on the bottom of the tank.
  9. Craftsman 944.360480 Carburetor O-Ring Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Craftsman 944.360480 Carburetor O-Ring Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the carburetor tank down slowly.
    • Empty any extra gasoline and use a rag to clean it out.
  10. Craftsman 944.360480 Carburetor O-Ring Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the O-Ring from the carburetor tank and replace it with a new one. You are ready to reassemble your lawnmower!
Priyum Mistry
crwdns2935283:001/10/22crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
York University, Team R-16, Melo-Thaiss Winter 2022 crwdns2935289:0York University, Team R-16, Melo-Thaiss Winter 2022crwdne2935289:0
YORK-MELO-THAISS-W22SRG16
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 940
