Cr-48 Chromebook SSD Replacement
  1. Cr-48 Chromebook SSD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook SSD Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook SSD Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To take out the battery, slide the switch on the bottom of the laptop.
    • The battery should then pop out and you can remove it.
  2. Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a pair of tweezers, remove the two rear rubber feet. You should then see the two screws underneath.
  3. Cr-48 Chromebook SSD Replacement, Remove Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook SSD Replacement, Remove Screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook SSD Replacement, Remove Screws: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, position the computer to have the silver battery compartment closest to you. Then, using a Phillips #00 screwdriver, remove the ten 3 mm screws in the battery compartment.
    • Now, using the same screwdriver, remove the two 4.5 mm screws that were underneath the previously removed rubber feet.
  4. Cr-48 Chromebook SSD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook SSD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook SSD Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  5. Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the SSD located on a corner of the side directly opposite where the laptop screen and device body are connected.
    • Remove one black screw on the SSD using a PH #00 screwdriver.
    • Size ph#00, approximately 3 mm long.
    • Once unscrewed, the SSD will pop up from the device.
  6. Cr-48 Chromebook SSD Replacement, Remove SSD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cr-48 Chromebook SSD Replacement, Remove SSD: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly grasp the SSD with two fingers slightly upwards and pull.
crwdns2935229:05crwdne2935229:0
Athar
crwdns2935283:009/09/14crwdne2935283:0
365 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 2-2, Bruce Fall 2014 crwdns2935289:0CSU Fullerton, Team 2-2, Bruce Fall 2014crwdne2935289:0
CSUF-BRUCE-F14S2G2
crwdns2942667:0crwdne2942667:0 3,674
