Cr-48 Chromebook Network Card Replacement
  1. Cr-48 Chromebook Network Card Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook Network Card Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook Network Card Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To take out the battery, slide the switch on the bottom of the laptop.
    • The battery should then pop out and you can remove it.
  2. Cr-48 Chromebook Network Card Replacement, Remove Rear Rubber Feet: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cr-48 Chromebook Network Card Replacement, Remove Rear Rubber Feet: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a pair of tweezers, remove the two rear rubber feet. You should then see the two screws underneath.
  3. Cr-48 Chromebook Network Card Replacement, Remove Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook Network Card Replacement, Remove Screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook Network Card Replacement, Remove Screws: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, position the computer to have the silver battery compartment closest to you. Then, using a Phillips #00 screwdriver, remove the ten 3 mm screws in the battery compartment.
    • Now, using the same screwdriver, remove the two 4.5 mm screws that were underneath the previously removed rubber feet.
  4. Cr-48 Chromebook Network Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook Network Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook Network Card Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  5. Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once you've removed the lower case, you should see the network card on the corner of the device containing the USB port.
    • Disconnect the Wire connections on the network card using forceps or tweezers.
  6. Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw (about 3 mm in length) securing the network card.
    • Once the screw is removed, the network card will pop up.
    • Pull the network card to remove it from the device.
Robert McLaughlin
crwdns2935283:009/09/14crwdne2935283:0
462 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 2-2, Bruce Fall 2014 crwdns2935289:0CSU Fullerton, Team 2-2, Bruce Fall 2014crwdne2935289:0
CSUF-BRUCE-F14S2G2
The card identified in the pictures is not a combined Wi-Fi / Cellular card. It is just a 3G cellular card; the WiFi card is the other card tucked under the flat ribbon next to the card pictured in this guide
Jorge Gomes - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,116
