Flip the device upside down and remove all of the Phillips #1 screws.
Use an opening tool to push on the retaining hooks to disengage them while prying slightly.
Remove the panel.
Use a Phillips #1 screwdriver to remove all four screws.
Lift off the bracket.
Use a Phillips #0 screwdriver to remove all the screws connecting to the shell.
Dissemble the shell going up to separate the basket holder.
Use a Phillips #0 screwdriver and the 150 mm Flex Extension to unscrew the bottom plastic connecting to the basket holder.
Pull the bottom shell down pulling at the sides to get them over screw holes.
Remove the screws holding the cables into the distribution board with a Phillips #2 screwdriver.
Remove the 2 cables that connect the heating coil to the distribution board on the top of the cooking chamber, there should be one blue and one white cable, both with a white shroud leading into the cooking chamber.
Flip the device backward so the metal walls appear in a U-shape.
Remove the 3 screws inside the cooking chamber that hold the heating coil in place using a 2 Philips screwdriver.
Remove the heating coil.
Remove the walls of the cooking chamber to get easier access to the fan.
Squeeze and disconnect the connectors.
Press the tab on the disconnector down then carefully pull it off to remove the wires from the board.
Use a Phillips screwdriver to remove the two screws from the motor.
Remove the screws securing the heat detector using a Phillips #1 screwdrivers.
Using a 3/8" socket, unscrew the hex nut holding the fan in place, making sure to not apply to much pressure on the fan to avoid warping.
Remove each piece to the roof of the cooking chamber.
Use a Phillips #2 screwdriver to remove the screws securing the motor.
Remove the motor.
Advice regarding a compatible motor?
