            Flip the device upside down and remove all of the Phillips #1 screws.
            Use an opening tool to push on the retaining hooks to disengage them while prying slightly.
            Remove the panel.
            Use a Phillips #1 screwdriver to remove all four screws.
            Lift off the bracket.
            Use a Phillips #0 screwdriver to remove all the screws connecting to the shell.
            Dissemble the shell going up to separate the basket holder.
            Use a Phillips #0 screwdriver and the 150 mm Flex Extension to unscrew the bottom plastic connecting to the basket holder.
            Pull the bottom shell down pulling at the sides to get them over screw holes.
            Remove the screws holding the cables into the distribution board with a Phillips #2 screwdriver.
            Remove the 2 cables that connect the heating coil to the distribution board on the top of the cooking chamber, there should be one blue and one white cable, both with a white shroud leading into the cooking chamber.
            Flip the device backward so the metal walls appear in a U-shape.
            Remove the 3 screws inside the cooking chamber that hold the heating coil in place using a 2 Philips screwdriver.
            Remove the heating coil.
Le ventilateur démarre pas , c’est quoi le problème ?
Does anyone know what´s reference of ic1 is on the distribution board? IC1 Image
